92 F-150 Problem
Old Nov 16, 2004 | 03:09 AM
Jrock909's Avatar
Jrock909
92 F-150 Problem
My truck has this intermittent problem with not wanting to start after the first startup of the day? I got 40 psi of fuel at the rail and when I start the truck up I get about 31 psi and it increases with blipping the throttle. I have spark too at the distributor so that leaves spark and gas out of this matter, I was thinking TFI module but how could that be when I am getting spark at the distributor, I remember way back when I had my fuel injected bronco II that it did this to me because of the plugs were fouled, could it be possible that the plugs are doing this to me, and if it is a plug matter. What is the best set of plugs I can buy bosch, autolite, champion, etc....? This matter has almost left me stranded at a gas station and a couple of restaurants, kinda worrying me now.... I am not throwing any codes either. I can start the truck up fine, but it's like when the truck gets warmed up that this problem exists, could be a bad ignition coil too maybe, but like I said I have good blue spark at the distributor I have brand new accel wires, brand new cap and rotor, plugs have a few miles on them but they aren't that bad, could this problem be a gapping problem with the plugs too?
