94 B3000 shuts off without warning
Shuts off within the first 15min of running. Other things running power like radio and lights don't budge. Does it in outside temperatures from 65 - 30 degrees so far.
Thanks to this board I did do a search and now have some ideas. Seems electrical to me ( starting system possibly), so far wasn't fuel pump relay. Trying coil next.
Seems like alot of guys blamed it on expensive items like fuel pump, etc and didn't do the trick. Would hate to spend money on replacing fuel sender and have same sympton. Thinking its more simple than that.
Any Thoughts or Similar problems????????
Jfuel
The next time it happens, I'd determine if it does not run due to lack of fuel or lack of spark. Did you throw that old fuel pump relay away? If not, insert it in place of the current EEC relay. EEC relays are sometimes known to cause intermittent problems.
Thanks guys- will give update
Jfuel
