Sponsored by: Auxito
new guy
Old Nov 15, 2004 | 09:50 PM
david64ad's Avatar
david64ad
Angry new guy
i have a 97 f150 4.6 ltr ,engine pinging when accelerating
and when coming to a stop rpm fluctuating below 500 and returns
to 550 constantly doing this check engine light on please help.
Edited to Lower Case [
Old Nov 15, 2004 | 10:23 PM
Mil1ion's Avatar
Mil1ion
Hello & Welcome to FTE!
This will explain why your thread was moved.
https://www.ford-trucks.com/forums/s...d.php?t=300691
Old Nov 15, 2004 | 10:26 PM
Rocky J's Avatar
Rocky J
The first thing is to pull the trouble codes, since the Check Engine light is on. I've heard here that your local Auto Zone parts store will read the codes for you if you ask.
Old Nov 16, 2004 | 12:00 AM
wmcnally's Avatar
wmcnally
david,
Pinging in the 4.6L is usually due to carbon build-up the Throttle Body and intake. The passeges from the EGR elbo to TB tend to get blocked with carbon.
The wacky RPM @ idle is most likely the IAC (idle air control valve) problem. Good chance it too is "gummed up"
Good Luck,
Bill
daisyq31
Escape & Escape Hybrid
May 8, 2013 10:25 AM
fixitman1310
May 1, 2011 08:46 PM
echavez1981
2004 - 2008 F150
May 30, 2007 09:23 PM
stu37d
Dec 7, 2006 09:24 PM
