1978 - 1996 Big Bronco
T_case Is A Go!!!!!!
Old Nov 15, 2004 | 02:05 PM
dammford's Avatar
dammford
i rebuilt the t-case and it WORKS!! but know i have a Q? i have 1990 bronco 112000K 300six E4OD my t-case went to ***** and i fixed it!yes! but how much longer tell the tranny goes??? it seem to shift good and dosent make any noise!!
Old Nov 15, 2004 | 04:37 PM
greystreak92's Avatar
greystreak92
The secret to longevity in ANY tranny or t-case is cooling, cooling, cooling. This is especially true of the E4OD. In short, if its running fine now, keep the fluid and filter clean and consider adding a seperate cooler if your truck doesn't already have one.
Old Nov 15, 2004 | 07:42 PM
body9599's Avatar
body9599
good job! I'm with grey on this one...cooler is better. You can also add an inline filter to help keep the fluid cleaner.
btw...I'm curious...how did the oil pump lugs look inside your TC?
again...good work.
Old Nov 19, 2004 | 02:03 PM
dammford's Avatar
dammford
they looked bad!!!!!!!! i had a budy in clase who is farther along in the welding program weld them up!! and it took me about 2hours sanding and fileing but 1k and no problems yet.?!?!
Old Nov 19, 2004 | 05:21 PM
dammford's Avatar
dammford
HEY!!! THANKS alot on all the help ...BODY>>>>
Old Nov 19, 2004 | 08:10 PM
body9599's Avatar
body9599
No problem dude...glad you got it going.
