Wiper Fluid
Old Nov 15, 2004 | 09:41 AM
dinty01's Avatar
dinty01
Exclamation Wiper Fluid
I just replaced the turn signal switch on the side of my steering column and now I dont get any fluid when i compress the end, I have wipers, turn signals, everything else, I checked fuses and relays but Im out of answers, anyone with some advice would be appreciated--Dinty01
P.S. The washer bottle is full of fluid too
Old Nov 15, 2004 | 09:53 AM
larry derouin's Avatar
larry derouin
New or used turn stalk???? Either way, pull off the end cap and clean the contacts that are in the end. Bets are the contacts ain't!
Old Nov 15, 2004 | 09:55 AM
dinty01's Avatar
dinty01
Its a new one from Ford, I pulled the old one out and replaced it with this one, didnt change anything else and now this problem, Im wondering if its a bad part?
Old Nov 15, 2004 | 11:00 PM
dinty01's Avatar
dinty01
bump bump bump
Old Nov 16, 2004 | 06:59 AM
Mauler's Avatar
Mauler
Windshield Washer Pump Motor
Maybe the pump motor is bad. Disconnect wires from pump motor and check the voltage there when the lever is pushed. May need two people - one at the voltmeter and one to push the lever - if you do not have long leads on your voltmeter.
Old Nov 16, 2004 | 08:31 AM
jcs1966's Avatar
jcs1966
how do you pull end off to clean???
Old Nov 17, 2004 | 09:12 PM
larry derouin
take a small folding knife or a razor knife and look for a seam on the cap (circumferential). Slip the knife blade in the seam and pry.
Old Nov 18, 2004 | 11:06 AM
qman's Avatar
qman
Why did you replace the turn signal switch? Was it because the washer pump wasn't working?
Old Nov 22, 2004 | 11:57 AM
dinty01's Avatar
dinty01
I replaced the switch because I was trying to get back my turn signals, flashers, etc and I had replaced everything else but that switch, now I have turnsignals etc but no wiper fluid, Im gonna try to see if I need to replace the pump as well this week, thanks-Dinty01
Old Nov 22, 2004 | 02:54 PM
Joboo's Avatar
Joboo
Dinty, i know im not going to be of much help here but...
I think i remember some years did not ahve the washer switch located in the turn signal stalk. If you perhaps were given the wrong part, or it was boxed wrong, you could have one of the switches that does not have a functional washer switch internal.
Just a thought anyway.
Compare all of the harness and connectors to the old switch. Are any of the connectors missing pins or pins located in a different position. Is the wiring color identical or a few wires missing?
Hope it helps.
