Feed/Return fuel lines???
Old Nov 14, 2004 | 11:55 PM
chefod's Avatar
chefod
Question Feed/Return fuel lines???
I have a 1992 f150 xlt with front and read gas tank, the front tank was not working when i bought the truck, i took it to a garage and they said I need a new in tank fuel pump, so they plugged off the feed/return lines, now I have the pump, can somebody help me locate the right way to connect it?? I know how to take the tank down, and I have new gaskets??? any help would be greatly appreciATED??
Old Nov 15, 2004 | 08:17 PM
quincyjr's Avatar
quincyjr
your best bet is to go and buy a mechanics manual for your truck, usually about $15. It will give you step by step instructions. Its not that hard of a job to drop the side tank. you have two straps holding it on. just loosen the nuts and it should lower right down.
