Offroad & 4x4
new style alternator
Old Nov 14, 2004 | 07:56 PM
79F350429's Avatar
79F350429
how does a person wire a new style(i believe G3)alternator into a '79 pickup?
Old Nov 14, 2004 | 08:15 PM
monsterbaby's Avatar
monsterbaby
I would post that question in the electrical system/wiring forum, or do a search there someone might have already asked that one.
Old Nov 14, 2004 | 09:12 PM
74fordtruck's Avatar
74fordtruck
youre talking about a one-wire, right? I believe you just run a wire to the starter solenoid and make sure it grounds out to the block and GO. I wished i'd done this for myself since i put a new regulator, alternator, and harness in and still have stock output.
Old Nov 14, 2004 | 10:08 PM
ivanribic's Avatar
ivanribic
You can run it to the battery post or the solenoid . . . same basic difference. I don't remember for sure now what it was but there was some re-wiring I had to do to the harness that runs through the regulator. Otherwise the truck wouldn't start. But it only took me about an hour to dig through the mess of wiring and figure it out . . . was pretty simple.
Old Nov 15, 2004 | 07:14 AM
bremen242's Avatar
bremen242
did you use a 5.0 3G alternator?? did you swap the pulley and did it match up ok?
Old Nov 15, 2004 | 02:12 PM
jopey's Avatar
jopey
bc broncos has a very easy to follow wiring diagram on how to wire in a 3g alternator in any engine you can fit the 3g case into.
I got one in my 78 bronco. It took about 30 minutes to swap in including removing the old one and doing all the wiring.
Just be sure you fuse the charging output on the 3g. 130 amps is enough to catch on fire real fast.
Bulldog187th
27
Aug 28, 2016 01:30 PM
ktm4012
Apr 22, 2016 05:58 AM
snowdog79
Dec 10, 2015 06:04 PM
79lownlong
Jan 6, 2015 08:26 PM
79f3504x4
Mar 22, 2002 06:11 PM
