need wiring diagram for my brakes on a 62 truck
You may find something here.
http://www.oldcarmanual.com/
What are you doing? A total re-wire restoration, or just trying to get them to work? What I can tell you is the brake circuit starts at a fuse, runs to through the brake switch, then up to the turnsignal switch in the column. The turnsignal switch combines the brake switch circuit and the turnsignal flasher circuit into one, because they both use the same side of the bulb in the rear.
You could click on wiring diagram, and ask the store if the factory service manuals have wiring diagrams in them. In the old days, they usually did. If you want to use your 64 diagram, the only suggestion is to find the brake switch and the turnsignal switch on your truck, and write down the wire colors. If your 64 diagram has the same wire colors, it's a good bet they are mostly the same.
