What dio I need to reflash the computer?
on
My "guess" is that the truck's computers would happily accept a flash to the older version but . . .
Either some form of configuration management is built in to the diagnostic computer at the dealer where it checks to see if the current version in the truck is newer than than the flash they are trying to down load, or the loader in the truck may do a form of this checking too - though I suspect not.
I would be that at Ford service centers where the techs and engineers spend time scratching their heads and other areas wondering about what's causing some issue, that they flash the truck fowards and backwards all the time. Probably just a check box on a dialog box, or a -xx option on a command line or something like that.
Most likely the can't go back to a previous version restriction is there to protect us customers from service techs that don't check to see if the version that they are trying to download is the latest or not.
I would bet a doughnut that they can do it.
Let's say your truck was out of warranty and you left explicit instructions not reflash your truck and they did perform this unauthorized repair. Since there are laws against this kind of thing, you could wave about a letter from a lawyer, and presto somehow they would put the truck back to the previous version.
Saxon, you may have some other problem. Harsh engagement is a symptom. Here is a service bulletin from Ford:
Harsh or Delayed Forward or Reverse Engagement:
This could be caused by a sticking line pressure control (PC-A) solenoid. Typically the line pressure will be fluctuatiing wildly (up to 500 PSI!). To service, first remove and insdpect the external cooler line filter. If it contains fine gray metalic debris. If metal is found, the source is most likely a defective revese planetary pinion shaft that is coming out of the carrier and contacting the case or adjacent components. The transmission will need to be disassembled and repaired as needed or replaced. Broadcast Message 3250
If little or no debris is found replace the line pressure control solenoid with P/N 4C3Z-7G383-AA. Broadcast Message 1586/SSM 17874/18051
This repair will require removing the solenoid harness, so a new harness sealing o-ring (P/N 3C3Z-7Z276-AA) will need to be installed. In some cases the solenoid body will need to be removed from the trans to remove the harness and solenoid. In this case the solenoid body gasket (basic P/N 7C155, trans tag number needed) will be needed as well. Note: Do not loosen the 10mm head bolts on the solenoid body. Only loosen the 8mm head bolts.
If the solenoid has been replaced and the condition it still pressent, suspect a contamination issue of the solenoid or a sticking pressure relief valve.
And by the way, I checked with some diesel techs. If your engine was built starting with Oct 1, 03 then you never had pilot injection. EGR strategy was used to quiet the idle.
