351M timing
Old Nov 13, 2004 | 04:59 PM
john7979's Avatar
john7979
351M timing
I just installed a rebuilt 351M in my 79 F-150 got it running but I had to advance the timing greatly to keep it running. The sticker on the valve cover says 10BTDC but I can't even get it close to that or it starts popping and wants to stall. Also it won't start unless I give it a shot of starting fluid even if a its been running and I shut it off for a second and try to restart it. Any ideas what could be wrong?
Old Nov 13, 2004 | 05:22 PM
Rancheroracer's Avatar
Rancheroracer
Maybe the damper has slipped on the rubber & timing marks off. Mechanically check tdc to see if damper tdc is correct.
Old Nov 17, 2004 | 10:29 PM
74 F100 351m's Avatar
74 F100 351m
I would never use strating fluid on a new motor, If you have to use somthing use WD-40.
Old Nov 18, 2004 | 03:06 AM
f250rangerexplorer's Avatar
f250rangerexplorer
i agree WD-40. i ran my boat off of this to get back to shore after running out of gas. 2 cans of WD doesn't last long on a 460. lol. didn't hurt the engine. that was about 150 hours ago. and it was fairly newly rebuilt. maybe 350 hours on it at the time.
Old Nov 18, 2004 | 01:54 PM
Rancheroracer
Won't restart
Sounds like carb accelerator pump problem if it starts when primed. Does it squirt fuel when looking down carb & working throttle linkage? Also, I once had a "slipped" damper & I set timing to highest vacuum at idle to get a starting point until damper fixed.
Old Nov 18, 2004 | 04:57 PM
john7979's Avatar
john7979
The accelerator pump on the carb wasn't working but I rebuilt the carb and now it works and it runs alot better. I set the timing to 10btdc it runs alittle rough but will run better around 16-18 so I think the damper has slipped.
Old Nov 19, 2004 | 01:30 AM
Rancheroracer
Try the vacuum gauge method & see where it ends up.
BDawg171
Nov 3, 2010 05:27 PM
boogaloo
May 26, 2010 02:23 PM
twinzilla
Feb 7, 2010 09:40 PM
cojam2000
May 13, 2008 07:07 AM
califasbob
Jan 25, 2006 03:41 PM
