302 rebuild
Old Nov 13, 2004 | 04:06 PM
ranger15's Avatar
ranger15
302 rebuild
whats the cheapest place to get a 72 302 rebuild kit
Old Nov 13, 2004 | 08:07 PM
packrat56's Avatar
packrat56
I went to a local machine shop, they had everything, prices were good, advice was there, could be cheaper places?
Old Nov 14, 2004 | 06:46 PM
DRanchero's Avatar
DRanchero
Summit's rebuild kit for hypereutectic pistons was $260 (better than cast pistons). If you want to have a supercharger or turbocharger or even nitrous, you would want to go with the forged pistons which will be about $430. Both kits include pistons, piston rings, main cam and rod bearings, a high volumeoil pump (some are standard), fel-pro gaskets, freeze plugs, plastigage, and assembly lube. That's what i went with. If you want the stock cast pistons, you will probably have to go to a shop in town. Good Luck!
