1978 - 1996 Big Bronco
Error Code Question 51, 54, 26...Help!
Old Nov 13, 2004 | 12:02 AM
llane915's Avatar
llane915
Arrow Error Code Question 51, 54, 26...Help!
ok i shut off my 1991 bronco with 5.8l auto transmission. i disconnected the battery for 4 hours and when i hook the battery back up without starting it i get error codes 51, 26, 54. this vehicles will start but dies once the choke cycles. once again i did not start it before i tested the code. also i was wondering if there is another way to reset the computer?
Old Nov 13, 2004 | 09:30 AM
Blue'87GT's Avatar
Blue'87GT
I'm trying to run down a problem onmy '96 as well. I found thi slink while searching that may help you on clearing the memory.
http://www.off-road.com/ford/bigbron...eec/index.html
