1986 4x4 rear diff
Old Nov 11, 2004 | 08:12 PM
civilpe's Avatar
civilpe
1986 4x4 rear diff
I need to replace my 1986 2.9L manual 4x4 rear end with a used one. Mine is a 3.73 gear ratio. The parts house said he has a 3.73 ratio off of a 1987 ranger 4x4 that has a 8.8 ring gear. Does it make a difference if my old one was a 7.7, as long as the 3.73. is the same?
Thanks in advance if anyone can help.
Old Nov 12, 2004 | 03:32 PM
Ken00's Avatar
Ken00
Welcome to FTE!!
I think it will work, anyone??
Old Nov 13, 2004 | 02:30 PM
backkmann's Avatar
backkmann
replaced differential in '94 Mazda 4x4 with Ford Ranger
you might end up with my problem ??...read on at
https://www.ford-trucks.com/forums/s...d.php?t=305033
do you think I'm having problems because the ring gears are different ? The mechanic says the gear ratio is the same .
Old Nov 13, 2004 | 05:01 PM
BOJOFASO's Avatar
BOJOFASO
are the tires the exact same size? if the rears are sdifferent from the fronts it will cause the problem you desrcibe.
was the problem there before you changed rears?
Old Nov 13, 2004 | 05:18 PM
backkmann's Avatar
backkmann
tires changed
I recently changed tires , went from 265 to 235. Do you think it could be the slightly smaller tire...I asked around and the word was it should make no difference. Altho the side sticker in the door frame says use 265 .
Old Nov 14, 2004 | 10:23 AM
BOJOFASO's Avatar
BOJOFASO
the 235 and the 265 is the width of the tire in millimeters. the 70 or 75 is the percentage of the tread width to the tire hieght. if you have say 265 70 15 tires they are not the same hieght as 235 70 15 tires. the width of the tire will have no effect but if the fronts or rear tires are taller than each other this will give you the vibration.
a small difference is accetable but more than a half inch will put strain on the drive train and will cause the problem.
Packard V8
Oct 27, 2009 06:20 PM
Budkole
17
May 23, 2005 09:23 AM
grumpyjjo
Bronco II
Aug 21, 2004 11:15 PM
horseshoer2375
Mar 2, 2004 09:42 PM
wojolsc
Jan 6, 2003 11:05 PM
