Manual Shifting Problems
Old Nov 11, 2004 | 01:17 AM
Robert1's Avatar
Robert1
I have a 1994 Ford Ranger XLT (6 cyl., 4.0 L; 4x4). Recently, the shifting of the gears has become very difficult. From nuetral to 1st is the most difficult. I checked the transmission fluid. When I removed the fill plug from the side of the transmission, red transmission fluid flowed out(I thought red fluid was only used for automatic transmissions and gear oil for manual transmissions?). At any rate, the fluid is full. Is the problem part of the clutch assembly? Is there a test for this?
Thanks,
Rob G
Old Nov 11, 2004 | 02:00 AM
sjwoody's Avatar
sjwoody
My 1990 manual transmission calls for ATF, apparantly you have the right fluid in it. Double check your manual to make sure. Sorry, I'm no help on your other issues.
Old Nov 11, 2004 | 03:30 AM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
It sort of sounds like the pilot bearing is going bad. When driving and shifting from 1-2, 2-3, etc, can you match the engine speed to the tranny input shaft speed and make shifting easier? If so, this is a strong hint that the pilot bushing is failing. When idling in gear with the clutch pressed in and not moving, if there are screechy sounds comming from the clutch area accompanied by "grabbing" and the vehicle trying to move, then this is another hint that the pilot bushing is failing. They don't get better, they only get worse. Let us know what you find.
Old Nov 11, 2004 | 10:38 PM
el conquistador's Avatar
el conquistador
Hey billy,
the pilot bearing and the throw out bearing are one in the same aren't they?
Old Nov 12, 2004 | 01:30 AM
CowboyBilly9Mile
Nope. The pilot bearing is in the end of the crankshaft and the throwout bearing slides on the nose of the tranny. The pilot bearing supports the input shaft on the tranny while the throwout bearing presses against the clutch pressure plate via the slave cylinder.
Old Nov 12, 2004 | 12:32 PM
el conquistador
thanx for the clarification bill
nitr066
Oct 13, 2012 10:10 AM
jrod82pa
Dec 3, 2011 12:14 PM
GRB1
Apr 9, 2008 09:59 AM
Frumious
32
Dec 5, 2005 06:37 PM
75crew
Feb 2, 2002 06:27 PM
