Offroad & 4x4
Losing the blocks
Old Nov 16, 2004 | 12:20 PM
  #31
proeliator's Avatar
proeliator
What makes you think its the same keg?
Yea, Ivan really needs to submit this as a tech writeup to Ken.
Old Nov 17, 2004 | 12:22 AM
  #32
ivanribic's Avatar
ivanribic
Originally Posted by Kymber
Ivan I looked at the front hangers on my 77 150 and the part of the hanger that the spring attaches to is revers yours. so if I were to flip the hanger for the rear the spring would have to attach to the top of the hanger. Did you have this issue?
Did I lose you?
Kymber, totally lost me there. Your hangers should be no different from mine at all. If you look at my shackle flip gallery pictures 1 and 2 are the stock bracket that sits at the REAR of the rear spring. In picture 2 I've just turned it upside down. In picture 3 I've replaced the stock bracket with a FRONT hanger for the rear spring. If you look at your hanger (the part that holds the front eye of the spring . . . with no shackle) it will look the same as the hanger than I used in picture 3. If you want to set it up like I did you need to buy a second set of hangers and just replace the rear brackets.
Don't know if this is making sense at all. It seems that it is really confusing to explain this with all the 'front' and 'rear' references. If it isn't clear let me know and I'll see if I can get some pictures that will provide more detail tomorrow.
Old Nov 17, 2004 | 01:43 PM
  #33
Kymber's Avatar
Kymber
No you made perfect sence I guess what I am saying is that the part of the hanger that I put the box around is reverese yours. Unless I am being a complete idiot (which is not that far out of the question) The spring eye would have to attach to the top of the hanger when flipped.Or did you just place he hangers higher on the frame with no flip?
Old Nov 17, 2004 | 01:44 PM
  #34
Kymber's Avatar
Kymber
sorry
[img]file:///C:/m.bmp[/img]
Old Nov 17, 2004 | 01:45 PM
  #35
Kymber's Avatar
Kymber
well that isnt really what I had in mind, check my gallery for the pic with the box
Old Nov 17, 2004 | 01:52 PM
  #36
ivanribic's Avatar
ivanribic
I'm not seeing it in your gallery Kymber. If you can't get it to work e-mail it to me at my user name @ hotmail.com so I can take a look.
Old Nov 17, 2004 | 01:53 PM
  #37
Kymber's Avatar
Kymber
ok I just reread your step by steep directions and I guess that tthe jury is in and I am a complete idiot. I got ya. I thought you were saying that the hangers were flipped. Nevermind me.
Old Nov 23, 2004 | 10:14 PM
  #38
jcab's Avatar
jcab
This may seem redundant, but I have a few questions. 1.) You flip front shackle of the rear leaf spring to get lift desired? Also move it forward 2 inches? 2.) The front leaf shackle on the truck should be flipped, and moved forward also?? 3.) How do you attain proper angle 35 degrees, do you flip shackle,install top bolts, and then drill holes through shackle after weight of truck moves it forward? 4.) And lastly how high do you raise truck to take weight off leaf springs to do shackle flip? Can you flip one side of front and rear, if you can't raise vehicle up high enough on both sides at once? Sorry for all the questions, but I would like to know how to do this before I get into it. And it sounds like it would be a good idea to weld back side of shackle with plate to reinforce for strength? Please advise Jeff
Old Nov 23, 2004 | 11:55 PM
  #39
ivanribic's Avatar
ivanribic
1, 3.) Your rear spring should not have a front shackle. The shackle will be in the back. If you use the stock bracket and flip it upside down you'll need to move it forward about 2" to acheive the proper angle. I found that if my shackle was straight up and down with no weight on the truck that it would settle to 35 degrees when I let the truck down.
2.) Don't know what you mean by your question. Are you talking about the front leaf spring or are you talking about a front shackle on the rear spring? Again, there's no front shackle on the rear spring. If you mean the front leaf spring the shackle already points down, not up. So there's no flipping it.
4.) Use a floor jack under the frame. You can do one side at a time. Use a keg for good safety so the truck doesn't fall on you.
Reinforcing the shackle would not be a bad idea as it will help prevent the ears from bending.
Old Nov 24, 2004 | 02:08 AM
  #40
jesse460's Avatar
jesse460
[QUOTE=ivanribic]
4.) Use a keg for good safety so the truck doesn't fall on you.QUOTE]
I suggest you empty the keg first, that way if the truck does fall you wont risk damaging the beer. Also your shackle will come out way cooler if you build them while plastered.
Old Nov 24, 2004 | 08:08 AM
  #41
jcab's Avatar
jcab
So this shackle flip will only raise the back of the truck, and not the front? I was hopping to raise the front also. Bigger tires could use couple inches clearance in the front. I already shimmed the front bumper. Thanks for the conmments, Do you know an inexpensive way to raise front of truck, without buying leveling kit? THanks Jeff
Old Nov 24, 2004 | 10:04 AM
  #42
ivanribic's Avatar
ivanribic
If it's a leaf spring suspension up front your easiest way will be to build longer shackles. Are your shackles for the front of the truck at the front or the rear of the spring? I know that on the 78/79 trucks (and I believe all the 80's trucks) the shackle is at the rear end of the spring and could be made VERY easily for only the cost of materials (maybe $20 tops). The only thing you'll have to keep an eye on is pinion angle. If your shackles are in the front it may be a little more tricky. Another option is to build drop hangers. This cost me about $40 in materials but will require a little more fabrication. I'll post some pics of both options Friday if not sooner.
Old Nov 24, 2004 | 11:02 AM
  #43
psychlopath's Avatar
psychlopath
Ivan Said: "4.) Use a floor jack under the frame. You can do one side at a time. Use a keg for good safety so the truck doesn't fall on you."
Heheh..yah..that's what I use a keg for when I work on my vehicle. The safety is so when the pumpkin settles onto my kneecap, I wont feel it as much, therefore remain more clear headed so I can yelp for help.
Some cheaper people slide a boiler maker under there for the same reason.
Old Nov 24, 2004 | 12:21 PM
  #44
proeliator's Avatar
proeliator
Clearly, some of us in here need to get together and publish a "Redneck Fabricators Handbook".
I'm in
Old Nov 24, 2004 | 12:24 PM
  #45
ivanribic's Avatar
ivanribic
Well I'd hate for the guy to get crushed under his truck and be laying there dying thinking to himself "Damn . . . if I only had a beer right now I'd be happy going out this way".
