Alternator output graph/specs?
Old Nov 11, 2004 | 03:51 PM
mzimmers's Avatar
mzimmers
Hi –
I have a 2001 5.4 F-150. I'm considering adding an inverter and battery bank, and I need to know what my stock alternator puts out. Does anyone have a graph, or at least know the numbers at various RPM?
Thanks...
Old Nov 12, 2004 | 05:08 PM
92GT5ohRed's Avatar
92GT5ohRed
Standard units are 95 amps. Make about 50 amps at idle and around 110 max at 6000 shaft rpms. The optional units were 130 amps, 65 at idle and 140 max. The 95a unit is about 5-1/4" diameter and the 130 is about 5-3/4 diameter. If you were really serious about output you could send me the unit and I could test it at any RPM or load you wanted and report to you the output.
Old Nov 15, 2004 | 11:33 PM
mzimmers's Avatar
mzimmers
Thanks for the information. If my window sticker doesn't say anything that suggests otherwise, can I assume my alternator is the standard unit? If so, I wonder if I can get away with a 90A battery isolator...I never let the engine get to redline.
JB78f150
2009 - 2014 F150
15
Oct 7, 2012 10:46 AM
tjustice
Jul 26, 2012 05:52 AM
Rancheroracer
Modular V10 (6.8l)
38
Apr 25, 2010 10:15 AM
