98 Ranger check engine light
Old May 11, 2002 | 09:34 AM
Jimn's Avatar
Jimn
I have a 98 Ranger 6 cyl/3.0 w/ 73,000 miles.
The check engine light came on and I took it to my Snap-On friend who diagnosed it to be the O2 sensor on bank #1.
How tough is this to replace? I'm not really up for the financial ream job my local dealer might nail me for, but can I be reasonably sure that the local garage can handle this?
Any idea how much $$ I should plan on spending for O2 sensor replacement?
I'm a real rookie on the repair end of things and I'm thankful that the truck has been running pretty darn well for the past 4 years.
Thanks in advance!
Jim
p.s. - the truck hasn't given me any symptoms of power loss and it only knocks a little on uphill grades.
Old May 11, 2002 | 10:02 PM
wptski's Avatar
wptski
I paid $60 at a auto parts store for one on a 97 Ranger 4.0L. It was on the other side which is lower end of the "Y" pipe and a bit easier to get to. Yours is higher up on that side.
It was either 15/16" or 7/8" hex. Mine broke loose after cutting the wires off so I could use the box end. It wouldn't come right out and I had to work it back/forth. A friend at work just broke one of his right off! This a guy told me that he sprays WD-40, heats them with a torch, lets them cool and reheats. Not sure if he followed his own rules this time
Old May 20, 2002 | 07:27 PM
Victour's Avatar
Victour
[updated:LAST EDITED ON 20-May-02 AT 08:34 PM (EST)]I also replaced the right Bank O2 hard to get to. AutoZone loaned me the Tool to remove it. (Deposit $15.) I used Blaster to spray it and let it set for 30 min. came right out on my 97 . Harder to unhook the wires than to unscrew the sensor...
Old May 26, 2002 | 03:36 PM
Jimn's Avatar
Jimn
Thanks very much for your help - I was out of commission and couldn't check back on the net for a while. I'll give it a shot!
- Jim
Old May 29, 2002 | 11:31 AM
katdaddy's Avatar
katdaddy
When changing an O2 is it a good idea to disconnect the negative side of the battery and reconnect after a minute or so to reset the computer?
Old May 29, 2002 | 03:42 PM
Ken00's Avatar
Ken00
I would recommend disconnecting the neg cable for 15 minutes anytime a sensor is replaced.
Old May 30, 2002 | 12:01 PM
katdaddy's Avatar
katdaddy
Thanks Ken.
Old May 30, 2002 | 02:02 PM
Ken00's Avatar
Ken00
WhyFord
163
Feb 17, 2017 07:49 PM
jmlkicker
Aug 4, 2015 12:00 AM
ckoneill
New Member Introductions
Oct 13, 2006 05:05 AM
Explorer98
Jun 27, 2006 09:28 AM
starmoon1222
Sep 1, 2003 08:06 PM
