Heater Control Has No Lights
Old Nov 10, 2004 | 05:37 PM
tyson724's Avatar
tyson724
my 93 ranger has no heater control lights . why ? bulbs out or panel dead ?
also my heat blow high speed only ??? resitor or motor ?
thanks
Old Nov 10, 2004 | 07:34 PM
captaincanuck's Avatar
captaincanuck
my 93 ranger has no lighting for the heater controls either, i was wondering the same thing, i think its probably just a bulb, but i dont no
Old Nov 10, 2004 | 09:00 PM
hreed's Avatar
hreed
The high only problem is probably the resistor. It should be located next to the blower motor on the heater plenum. When you take it off, there will be (I think) three wire coils and more than likely one of them has burned or come unattached. I have soldered these before and it works ok but it's worth checking into a new one. The lengths are not critical, so you can trim them and it will still work or splice a short piece of wire if it is too short. Make sure you use the same guage wire. If the resistor checks out ok, it is either in the switch or the wiring. An ohmmeter should tell you where the problem is located by probing the resistor connection to ground at each pin and corresponding switch position. Make sure the key is off or the battery is disconnected. The bulb for the heater control is probably burned out. Check it first.
DerrickR
20
Mar 25, 2025 06:34 AM
Niwrek
Jan 26, 2016 07:35 PM
DarylWork
Modular V8 (4.6L, 5.4L)
Mar 30, 2015 04:23 PM
Michael9280
1997 - 2003 F150
Apr 28, 2014 11:15 AM
f150joek
1997 - 2003 F150
Sep 24, 2011 06:20 PM
