A4LD problems
Old Nov 10, 2004 | 05:30 PM
mytwistedvisions's Avatar
mytwistedvisions
Question A4LD problems
I just traded for a 1991 Explorer 4.0 4WD with a A4LD tranny. At first the selecter lever would only go down into Drive, and not into 2nd or 1st. Also there was no noticable park or reverse. I unhooked the cable end at the transmission and was able to manual move the shift lever on the transmission into park.By rocking the vechicle a little I was able to get the parking pawl to engage with the engine off. I had my son start the engine and apply the brake. I then manually moved the lever on the transmission one detent click (for Reverse) no reverse, but it wanted to move forward. I saw that the lever on the transmission appered to be bend in towards the transmission. I strightened it and reattached the shift cable. I was then able to move the selector in side the vechicle into all ranges. However, when in park, reverse, netural the vechicle still trys to move forward. Transmission fluid appears a little burned, by that it is a lite brown instead of nice red. I relize that it likely needs an overhaul, but was trying to determine what caused the problem, and what to look for when I get it torn down. I have done overhauls on many c6 trannys and had great success. I have done a few AOD's and had several of them eat my lunch... Or is there a simple solution to the tranny problem?
erkmadhatter
Escape & Escape Hybrid
Aug 16, 2012 11:26 PM
ferant316
1997 - 2003 F150
Oct 21, 2010 11:12 AM
'94Mesquite
Jul 29, 2009 02:56 PM
Terryfromok
Oct 7, 2005 09:25 PM
friedslacks
May 11, 2004 01:09 AM
