Hello. New to the forum and could not find another post which identifies my question.
I have a 99 F350 CC DRW that needs a parking adjustment. I've found the adjustment roller but cannot seem to get the adjustment correct. Which way do you move the adjustment roller to increase the tension on the brake?
If the adjustment roller is fully tightend, would the next course of action be to replace the pads? If so, is this just as simple as removing the rotors to gain access to the pads?
Don't know about the 99's but my 97 is "self-adjusting". Like the mustang clutch cable setup. There is no provision for adjustment. If broken the entire park brake assembly has to be replaced.
The parking brake on our trucks are self adjusting but they can wear out. Inside the rear rotors is a small brake almost like a drum/shoes for the parking brake. Your shoes wear out, your brake doesn't hold.
Wether this is true or not I'll soon find out. But it's something I have to say I didn't know about.
Hello. The parking brake on my 99 is located in the drum of the wheel. Underneath the truck and on the back side of the wheel there is a oblong rubber gromet. If you pull this out you can see the adjusting wheel. This wheel moves up and down.
If your vehicle has drum brakes they should be automatic adjusters. You may need to remove the drums and check them. The adjusters are probably frozen.
With disc brakes its a manual adjustment. Same system I've got. My truck wouldn't hold in my driveway so I installed a MICO lever lock system to the front brakes. My p-brake is adjusted properly and sets tight. It holds better in reverse than forward but not safe enough to leave unatended.
As I understand it, the adjustment roller on the backside of the wheel needs to be adjusted to tighten up the brake. If the roller is adjusted all the way and the truck still moves, then I suspect the pads which are inside of the rear drum need to be replaced.
This is only the assumption at this point as I was looking for clarification.
Thanks
disc brakes dont have a drum. anyone know how to adjust the p-brake on a DISC BRAKE setup?
