Starter
Old Nov 10, 2004 | 12:30 PM
TheOld86er's Avatar
TheOld86er
Starter
My 86 F-150 requires gas to be pumbed in before it will start, what would cause this?
Old Nov 10, 2004 | 02:53 PM
Holmesuser01's Avatar
Holmesuser01
Nasty Carb, Maybe?
What are the chances that the carb needs to be rebuilt? Fuel filter? Fuel pump?
With the motor not running, remove the air cleaner. Hold the choke open with your fingers, and manually open the throttle. Do you see gas squirting ? A bad accelerator pump in the carb can make it a real joy to start.
