exhaust question
Old Nov 10, 2004 | 09:13 AM
redneck93375's Avatar
redneck93375
Question exhaust question
after reading through a few posts I just want to know if there will be a benefit to just removing the cat and muffler from the factory exhaust. I just purchased the predator and wanted to free up some exhaust. However, I just can't afford the exhaust kits with the larger downpipe right now. Will it be beneficial if I just have them cut out the muffler and cat and run straight pipe with the factory 3 inch exhaust?
Thanks for the help
Old Nov 10, 2004 | 09:21 AM
jasfaa's Avatar
jasfaa
Thanks for the help
IMO, I would not touch the CAT.
Old Nov 10, 2004 | 10:03 AM
jdadamsjr's Avatar
jdadamsjr
Welcome to FTE, Redneck !!!!
EGGxactly what I did at first...
I did a straight pipe with my X to see if it would do what I wanted....
ran it that way for 6 months ...
Did lower my egt's and free up the exhaust...
sounded super around town and all... but ....
In the LONG "cab" of my X it was too much drone for the long drives over a couple of hours....
in your SD it may be fine since the cab is shorter than mine...
eventually did get a turbo back exhaust installed....
I left the cat in since others have tested and not seen any difference with or without cat....
( it IS a BIG federal fine if you get caught )
Old Nov 10, 2004 | 11:40 AM
redneck93375
Thanks for all the replies. I went to the muffler shop and we took a look at the underbelly of the beast. It didn't take long and I whipped out the discover for a four inch turbo back kit. I deleted the muffler and just ran straight pipe all the way. Probably will be a bit noisy, but I have a serious sound system to drown out some of the sound. Darn salesmen, they get me every time.
Old Nov 11, 2004 | 05:17 AM
t_j82's Avatar
t_j82
Leave the cat! There is virtually no restriction to it. I was told by the field service rep that this system needs some back pressure to operate the variable veins on the turbo so he said to avoid straight piping.
Old Nov 11, 2004 | 01:07 PM
SBV45's Avatar
SBV45
t_j82: Leave the cat! There is virtually no restriction to it. I was told by the field service rep that this system needs some back pressure to operate the variable veins on the turbo so he said to avoid straight piping.
There has been some debate on that. I concur with that analysis. The Exhaust Pressure sensor is at the end of a tube that is between the manifold and the turbo. The exhaust pipes and cat is post turbo. Some people say that if you modify the exhaust post turbo it has no effect on the EP sensor. I suspect it does to some degree. The EP, BARO, MAF and MAP all input to the PCM which in turn controls the VGT actuator to move the vanes to direct exhaust onto the turbines. They are inter related.
I would like to see some analysis done to see if there is an effect on the EP sensor if the exhaust is stock and if it is modified.
Old Nov 11, 2004 | 03:15 PM
Ben Alston's Avatar
Ben Alston
the first week i bought my truck i took off the cat and the muffler big diffence in power/sound
