Front end clunk
For some paint issues etc etc.. Front end makes clunk noise when shifting from P to D or R to D. Suprise! they cant figuer it out. Sent them info I recieved from Realmenpowerstroke but I have this feeling they are still going to be eatn lunch scratching they're heads and still not solve this prob. Any Ideas? Oh, and sometimes it can take up to 20' before I hear the noise and feel it if its loud enough. This is my second post and damn this is a wealth of info. Thanks all
Mike
Your's is probably something different altogether, but thought I'd throw that out there.
Clunk or Pop from TorqShift at 2-3 MPH:
A clunk or pop may be heard or felt on drive away after starting the engine, backing up and shifting to drive, usually around 2-3 MPH. This condition may be intermittent. It is the result of normal backlash (movement) between the splines on the low/reverse one-way clutch. Broadcast Message 1335
So Ford sez it is normal. OK but my buddy with an 03 Chebby Duraweak 2500 has no driveline noises at all. OK so his truck is basically a Trailblazer on bad steriods, so I guess there is no comparison.
It has never seemed to get worse so I suppose that I will let it slide for now. I am going back to the dealer for "Exhaust in the Cab" when I get finished with big project at work that is taking all my time. I will mention it to them then. Maybe show them the Broadcast message that SBV45 posted.
Thanks,
Big
http://www.intellidog.com/dieselmann/60bulletin.htm
Do a search for exhaust. There is a bulletin for that too, I think.
This is relaly startting to bother me with Ford, and i am sure other manuf. do it to. But look at all the post on this forum regarding issue's, and look at how many times Ford's mechanics are stumped. I to work in a field where i have to diagnose problems, and resolve them. I don't know where the ball is being dropped at. If its on Ford door step, or the dealership's for not getting the proper training for there diesel tech's. Quality service just seems like it is a thing of the past...
Just my opinion...
PSDboy
03/ built4/28, drw 4x4
http://www.eurekaboy.com/f250/slipjoint.htm
2004 F-Series/Excursion Steering Grunt/Moan:
If a steering system exhibits a grunt or moan that sounds like it is coming from the steering gear or column, especially on left turns, do not attempt to repair the condition as engineering is investigating the concern. Broadcast Message 1461
I find the problem is with service advisors trying to act knowledgeable when they aren't. They give the dealer and Ford a bad name. I have had service advisors tell me all kinds of bs. I find it valuable to be informed. I bought service manuals and research on the Internet. But be sure of the sources if it comes off the Internet. Things tend to get blown out of proportion.
. I have to say that I'm pretty impressed by the service. Had some paint drips on the lower part of a couple doors and some chips on the hood. The drips were warranty probs but the hood was not. they ended up respraying the entire hood as well as the drips. Now down to the mech probs...For my power fluctuations the replaced my EBP sensor and reflashed the PCM to 4U7A-12A650-EHB. Only time will tell if that solved the problem as it was an intermitten problem. Front end cluck goes as fallows: " EPC SOL inoperational 7g383. NVH diag. found cluck was from trans or transfercase area. Trans tester hook-up no DTC, Pin point tested pressure test reading erratic. Removed pan for inspection, For ssm 18209 no sign of planitary failure at this time. Removed v/body to check for sticking valves. ok. replaced EPC sol. preformed adaptive strategy, retested EEC no dtc" If anyone can translate that into plain English I would appreciate it. Hope this helps some of you that get the favorite "Oh thats normal" response from your dealer.PSDboy I agree that having to research for techs
is pretty sad, but if it insures a correct diag. and repair I'll keep doing it until they can get it right.Mike
04-04 build date. f-250 psd 4x4 Lariat
They replaced the 'exhaust back pressure' sensor and reprogrammed the trucks computer with the latest calibration for driveabilty/running concerns..
Also ID'ed the front end noise as coming from the trans area using the 'NVH' (noise/vibration/harshness) diagnostic.. Also tested/scanned for dianostic trouble codes (DTC's) with none found.. The pinpoint test involves using a volt/ohm meter ect. and is used to test circuit resistance/voltages and they felt that the EPC (electronic pressure control solenoid) for line pressure in the trans was out of spec. or non functional.. They also pulled the trans pan/valve body for an 'exploratory' look see, for a stuck/sticking valve, and/or for signs of 'abnormal' metal/s and wear or componant failure.. Preformed adaptive strategy to complete the repair, check for shift engagement/intervules, with a final check for trouble codes..
....................HP....................
Comments like this always make me nervous. When a statement ends with "not at this time"... or similar...IMO, it implies that the issue is anticipated at some point in time.
If you know what I mean.
