1978 - 1996 Big Bronco
electronic t-case problem
Old Nov 10, 2004 | 04:31 AM
91 SilverBronco's Avatar
91 SilverBronco
Angry electronic t-case problem
When I push the 4x4 button the alt gauge drops, thre idle drops and nothing else happens. HELP
Old Nov 10, 2004 | 04:55 AM
greystreak92's Avatar
greystreak92
The shift motor is stalled for some reason. Probably due to misalignment. The electronic B/W T-cases are notoroius for it across the entire Ford line of trucks. Check this link for a detailed explanation of the shift motor and the problems that are encountered with it along with some solution procedures.
http://www.glue.umd.edu/~singletn/web/pages/tcase.html
The T-case discussed is a B/W 1354 which is a smaller derivative of the 1356 in your Bronco. Essentially they operate the same way.
Old Nov 11, 2004 | 02:52 PM
desertdave35's Avatar
desertdave35
Mine did the same thing, took it to Ford and they fixed for $400.00. The motor was bad in mine I guess.
