Engine misses when warm.
Old Nov 9, 2004 | 06:55 PM
TBloggins's Avatar
TBloggins
This has just started happening. I have a '88, F150, Lariat XLT, 302 w/ EFI. The truck starts and runs fine in the morning, or after sitting for a couple of hours. However, after about fifteen minutes and warming up, it starts to miss. Not like a fuel problem, both tanks and pumps have been replaced. More like an ignition problem, like a loose wire or something. I thought the coil was breaking down, so I replaced it. Same problem. Had everything checked about 3000 miles ago (plugs, wires, codes, etc.) everything was fine. I'm stumped. Anyone got any ideas? Thanks.
Old Nov 9, 2004 | 09:50 PM
mike L's Avatar
mike L
Starting problems
Welcome to FTE. Have you got any trouble codes? Check engine light on? Might have some trouble code in memery. Change the fuel filter with a Motorcraft, not Fram! Go to www.fordfuelinjection.com under getting trouble codes on the right side ? of the page. New web page. Do you have two fuel tanks does it do it for both tanks?
Old Nov 9, 2004 | 09:57 PM
TBloggins's Avatar
TBloggins
Yup, two new tanks, pumps and filter, does it on both tanks. It seems more and more that it may be the TFI from what I've been reading. It acts more like an electrical problem than a fuel one. Seems only to affect the truck when it warms up. Thoughts? Thanks.
Old Nov 9, 2004 | 10:06 PM
mike L's Avatar
mike L
Electrical problems
Check the trouble codes its worth the little time it takes. Plus you will get more replies. The first thing FTE members what to know is what are the trouble code numbers.
Old Nov 9, 2004 | 10:07 PM
scjfox's Avatar
scjfox
There was a tsb on the tfi modules for those, I got one along time ago when I owned my 88 with a 351. Replaced it and it ran fine
Old Nov 9, 2004 | 10:12 PM
mike L's Avatar
mike L
Test the parts and wiring first. Take your time. Get a Haines ? manual which will give you the voltaged that needed.
Old Nov 9, 2004 | 10:22 PM
TBloggins's Avatar
TBloggins
Thanks guys. Will do.
Old Nov 10, 2004 | 03:46 PM
TBloggins's Avatar
TBloggins
Thanks guys. Changed the TFI, problem solved.
linckeil
Jan 25, 2015 11:49 PM
CountryBoy685
Nov 5, 2002 12:25 AM
ws23l77187904
Sep 27, 2002 06:33 PM
