Pertronix or MSD
Old Nov 9, 2004 | 05:04 PM
pkulaga's Avatar
pkulaga
Pertronix or MSD
Im in the process of junking my old faithful point system for a new shiny electronic ignition system. You guys have a preference between MSD and pertronix?
1970 F250 Sport Custom
390 w/flattops
Comp 268H
Holley 670 SA
stupid stock iron extra super heavy intake (soon to be an Edel RPM)
C8AE-H heads
Old Nov 9, 2004 | 05:18 PM
debestuss's Avatar
debestuss
There are guys in here that race with the old point system. It all depends on how much you want to spend for an electronic ignition. MSD if you've got a few hundred laying around but you'd get just as good a system with a less expensive Pertronix Ignitor and supercoil. My .02.
Somebody else will chime in their .02
Old Nov 9, 2004 | 07:16 PM
"Beemer Nut"'s Avatar
"Beemer Nut"
No more points
I've been running the Allison optical trigger system, now called the XR700 series by Crane. Running it for 14 years without any trouble. Crane purchased Allison. I have a XR3000 (FireBall) trigger with LX-91 performance coil thats hotter but haven't installed yet. The coil thru Summit was $49, XR3000 was $127 (?). If you use a Pertronics trigger you may be limited on the amount of current the trigger can handle, no high current hot coil. I had a MSD system that failed twice in three years, hence back to the old Allison. Carl...o&o>......
Old Nov 9, 2004 | 08:35 PM
gtex's Avatar
gtex
On a limited budget go with the Pertronix/stock system.
At the next level I consider there to be 2 choices. The MSD and the DUI. There are other brands comparable to the MSD that you hear about every so often.
If I had it to do again, I'd probably try the DUI for my build. If I was building a straight race motor for the most HP, then I might stick with the MSD.
I've had many parts fail in the MSD system, but it appears to be working now. And it's easy to adjust for hotter engines.
Old Nov 9, 2004 | 08:46 PM
Spaznaut's Avatar
Spaznaut
Had a MSD system on my Mustang and had the pick-up fail twice on it. Easy and cheap to replace but pain to figure out.
Have a Mallory system that has never given any problems.
Only 2 aftermarket systems I have any experience with.
Old Nov 10, 2004 | 02:51 PM
tbirdrief's Avatar
tbirdrief
I have been using a Pertronix system for about 30,000 miles now. The plugs are gaped to about .040 and starts like a champ. I also run the the flame thrower coil at 40,000 volts. For around $100 and 30 min. time works great.
Old Nov 10, 2004 | 02:57 PM
pkulaga's Avatar
pkulaga
Are you also running the PerTronix dizzy or just the ignition system? Can't decide which dizzy to get. MSD is so expensive but its almost too shiny to pass up .
Old Nov 10, 2004 | 03:03 PM
Six Niner's Avatar
Six Niner
ive got a pertronix on my 390 now with the stock dizzy and big cap. has worked great and an easy install. ive got an MSD billet dizzy and 6AL on my falcon. pickup failed once but other than it works good. depends on how much you want to spend. my 2 pennies worth.
Old Nov 10, 2004 | 03:08 PM
Bigles's Avatar
Bigles
Ran several of the old Pertronix, Perlux as they were called then, on my 361 & 391 school buses. They always preformed well. They would compensate for a worn distributor. Instead of adjusting the dwell every other day, you could install the Perlux and forget about the distributor.
Bigles
Old Nov 10, 2004 | 05:53 PM
pkulaga's Avatar
pkulaga
Im kind of leaning more toward the PerTronix stuff, but what about a dizzy? Im not sure which one to get, and I can't seem to find much info on a Pertronix FE application.
Old Nov 10, 2004 | 06:54 PM
EgoMan's Avatar
EgoMan
Just go to the autoparts store and buy a brand new OEM dizzy there like 40 dollars.
Old Nov 10, 2004 | 06:57 PM
baitmaster's Avatar
baitmaster
cheap stuff
I had gotten tired of messing with points on my 390, so I went with a rebuilt diz ($45) from Pep Boys, and Pertronix $69) from local outlet. No probs for 8 yrs. I suppose its time to change cap. Also thru in Accel coil and fat plug wires. Plugs gapped at .045
Outlaw56
Mar 15, 2016 03:30 PM
351Cleveland C4
Feb 25, 2016 06:43 PM
fordguy98
Dec 12, 2015 01:31 PM
Jag Red 54
15
Oct 26, 2006 09:45 AM
charliemccraney
Jul 18, 2003 09:37 AM
