A few questions about going to a solid flywheel
Old Nov 9, 2004 | 02:26 PM
Spooky's Avatar
Spooky
I have a 95 f-250 and just found out that my dual mass flywheel is bad, and being a broke tech school student I dont have any money and I was thinking I could get a used solid flywheel out of a 94-97 F-450 if I could find one and switch it over. now my question is would I have to get the pressure plate and clutch disk with it or would the pressure plate and clutch disk that I have on the dual mass flywheel work with the solid one. I know that it would be best to get the whole luk package but I cannot swing that much $$$ right now. thanx guys
Old Nov 10, 2004 | 10:37 PM
01stroker's Avatar
01stroker
I believe that you will have to change the clutch and pressure plate when you convert to a solid flywheel. They are different.
Old Nov 10, 2004 | 10:43 PM
Kwikkordead's Avatar
Kwikkordead
How about the whole setup out of a wreck, flywheel, pressure plate and disc? Just make sure it's not all rusted out from sitting in the rain.
Old Nov 10, 2004 | 10:52 PM
ltfox's Avatar
ltfox
The clutch disc for the DMF dosen't have any dampner springs so you'd have to get the whole set-up out of one like kwik suggested.
Old Nov 11, 2004 | 11:14 AM
Spooky's Avatar
Spooky
Yea that is what i was thinking of doing, getting one out of a truck at a salvage yard. I was told by a knowledgable person that the clutches in the F-450 were solid. I plan on making a 2800 mile trip next week and if I dont get it fixed will that cause any problems. It doesent seem to vibrate when I am cruising. I just wonder if it will start to take out the rear main bearing. Thanx guys
