Well I found it last night. I took the fuse box off and turned it over and that is where it was supposed to be.
Because it was missing it was pretty difficult to determine if it even went back there. But I found a spot that had what appeared to be the two prong inserts that are at a 90 deg angle. It is directly opposite of the turn signal flasher.
THere is no "second" flasher unit for the hazards....Turn and hazard use the same flasher unit. What you see on the back of the fuse panel is nothing more than the back side of where the flasher unit plugs in on the front. I have the wiring diagram on my system for your truck....if you want I can send em to you. If you post your email address in here using the @ symbol, the forum admin will remove the address from the post. So you will need to get creative. Let me know.
(or send your email to my junk one...hrsn_rnd (at) yahoo.com)
