There should be a light on your dash that says 'wait to start', it will be on for a few seconds and then go out, after that you should be good to start. Usually depends on how cold it is, the colder it is the longer you'll have to wait. I'm not sure, but when the light goes out, it doesn't mean that the glow plugs have quit heating, so if you sit there a little longer, I think they will still keep heating. And if not, you can turn your key on, let the light go out, turn it off and on again. And if it's cold enough it always helps to plug your truck in, it'll make it a lot easier to start.
If you watch your ammeter you should see it go way over into the discharge side of the gauge. This, not your "wait to start" lite, is a correct indication of the glow plugs turned on. If it is cold enough, and you wait a couple of minutes the gauge will return to approximately center - glow plugs should now be off.
Observe this operation - it may be helpful in the future when you are trying to troubleshoot a hard to start problem. If you catch enough clues when your truck is operating properly it helps you see when something is wrong.
I was reading my ford diesel supplement to my 02 PSD. It says the plugs will shut off after 2 min. So I believe you can leave it "keyed" to long.
Yeah, but it also says by turning the key to Off then back to Run, you reset the cycle. The 2 minute timeout is so you don't kill your batteries if you turn to Run and don't start your truck.
__________________ 2002 F-350 XLT 4x4 PSD 6spd SC SB SRW
2001 400ex SportTrax
1990 F-150 Lariat 4x4 I-6 5spd RC SB
---Also in Family---
2003 F-250 XLT FX4 6.0PSD TSA SC SB
2001 F-150 XLT 4x4 5.4 AT SC SB
Uh, didn't really mean that this is wrong farmb0y, I just ment to clarify that the "wait to start" is just an indicator.
sorry.
I know what you meant. I've heard about it before, and should try and watch that, now that it's getting cold around here. Should see how accurate it is, and go off that than the light. I'm not a big fan of the light anyway.
When I've bench tested glow plugs they are red hot within seconds. I would say waiting for the WTS light to go out is quite adequite. Any more than that and IMO you're just overstressing the glow plugs. I don't know if they are set to turn off as soon as the engine is running though. Anybody know?
I am the proud owner of a 1995 F250 with the PSD. The temperature is dropping some and I am having a tough time getting started in the morning. The owners manual states that the veh should be plugged in if temp falls below zero degress F!!! Can this be correct???? I may have a fuel injection situation also because i have copious amount of white smoke once i get the engine started.
HOw much pedal should I give when starting?? Half way down???? an inch or two????? The vehicle is parked outside and I am concerned that things are just going to get worse as the snow starts to fly. This is my first diesel engine so thanks for everybodies patience as I learn my way around my PSD
With a glow plug system that is functioning correctly you should have no trouble starting your engine at anything above 20 degrees, without plugging in. (Providing your engine has good compression, most PSD engines do.) If you are having trouble now and I assume the hard weather hasn't hit yet you probably have some burned out glow plugs, non functioning relay, crusty wiring harness's inside the valve covers. Just one burned out glow plug in cold weather will make copius amounts of white smoke on a cold startup. You can be missing up to half of your glow plugs and it will start, but with difficulty and LOTS of smoke until warm enough for the fuel to ignite in the cold cylinders. Get them all working and it will start very easily.
.....HOw much pedal should I give when starting?? Half way down???? an inch or two?????
NONE!..................
I don't know where I read or heard this, but you're not supposed to depress the accelerator while starting (or attempting to). It's bad for the engine. All I know is some part of the engine (I'm assuming the fuel pump) does all the work.
On my 94 the glowplugs stay on for 1 1/2 to 2 minutes after the key is turned on. At night wait till the "wait to start" light goes off, start the truck , turn the lights on while idling and watch the lights go from dim to normal brightness after aproximatly 2 minutes after first turning the key on to start the glowplug cycle.
