rear differential leak
If so, how hard is it to replace this seal?
'91 Ranger, 2.3L, 2WD, 165k
Disconnect the drive shaft.
Mark the yoke nut and the yoke so you can put it back where it was.
Remove the nut and the yoke.
Pull the old seal out.
Put the new seal in.
Reassemble and either torque the nut to specs or line up the marks you made.
When you have the yoke off, check the surface where the seal rides. A lot of times the spring that holds the seal to the yoke will wear through the seal and carve a groove in the yoke. If that's the case, replace thet yoke or it'll still leak.
Hope this helps.
Kevin K.
I feel pretty confident I can disconnect the shaft from the differential and get to the seal, but I don't want to get into the job and find out I need these special tools. How much would the necessary tools cost? I don't see myself going into the rear end business, so if the cost gets too high, I'll probably get it done in a shop. What do you think is a reasonable price to pay to have this seal replaced?
There are two ways to do most jobs. The right way, with all the specialty tools that mechanics pay thousands for to do every job, and the way the rest of us do it that works just as well if you use your head. It might take a little longer, though, and you might have to be a little more careful.
Most of the time, for example, you can use a hammer to install a seal, as long as you're careful to drive it in straight.
As far as the pinion seal goes, do a search, it's been covered many times. I seem to recall needing a large torque wrench for the pinion nut.
