Heater fan motor wont come on
I have 92 full size bronco Edie Bauer. Fan motor on heater does not worrk. Is there a fast and simple way to check and be sure it is not the motor that is out. can you jump the motor somewhere without going thru the complete electrical troubleshooting. Fuse is OK Thanks Guys
I have use jumper wires under the hood before and run a hot wire and ground where the motor plugs in (usually on the back of the motor) and tested them that way. You can also use a test light at the same connector and see if your getting power to the motor. Have you checked all of your fuses first?
Originally Posted by greystreak92
If you have power at the fuse, a good fuse, and the motor is not running, you can jumper power directly to the motor via the ORG wire (pos.) and the BLK wire (neg) running to the motor. If the motor runs when power is supplied, the suspect component is the resistor assembly.
