Found Old Ford Engine
Old Nov 8, 2004 | 07:48 AM
f700's Avatar
f700
anyone good with engine numbers, i found a old ford motor numbers are :FH12140S
Old Nov 8, 2004 | 09:19 AM
gtex's Avatar
gtex
Where is the number located?
How many bolts holding down the valve covers? That's one way to get a good idea what engine family it is for a Ford.
5 bolts and you've got an FE. Identifiying the actual displacemnet is a bit more challenging.
Old Nov 8, 2004 | 08:11 PM
f700's Avatar
f700
casting numbers
hi can tell you that the dizzy at the front , cast numbers are c7te842b
firing order is 15426378
Old Nov 9, 2004 | 03:24 AM
FrameRotBlues's Avatar
FrameRotBlues
The cast-in code (from the intake manifold? missing one digit) looks to be a '67 truck motor. But you probably already knew that anyway.
If the coil sits on top of the intake manifold near the distributor, there may be a tag under it that will tell more.
The door tag from the cab will also spell it out - I'm not sure how the truck VIN decode works, but the car engine letter was the 5th digit in the VIN number.
Old Dec 25, 2004 | 11:18 PM
f700's Avatar
f700
hi again just took the heads off that motor numbers on the rod s are, c 7 t e a on one side , a60 j ,on the second slided, head casting number s are , c7te-c im thinking a 361 fe ? hope you had a good xmas
