Lost Hi Beams...
Old Nov 7, 2004 | 08:12 PM
smitty240's Avatar
smitty240
Red face Lost Hi Beams...
2003 F-250. 10.8k miles. I abruptly lost both hi beams do to electrical problem. Not the fuse (checked old one, was OK, tried a new one just in case), have power to fuse receptacle on supply side, tried new bulb, no power to bulb recepticle. I'm almost positive there must be a relay in this circuit, but none of the manuals available have wiring diagrams for this year truck. Any one have any ideas or can point me in the direction of a relay or additional fusing for the hi beams? Thanks.
Old Nov 8, 2004 | 02:10 PM
Franklin2's Avatar
Franklin2
Start poking around the steering column. Your truck is pretty new, but I am guessing they still use the multi-function switch(turnsignal switch), to switch from high to low beams. You may have a melted or loose connection up in the column.
