intermitten starting problem
Old Nov 7, 2004 | 04:21 PM
triplethreat's Avatar
triplethreat
I have a '96 300 manual trans. a few weeks ago when i tried to start it it would crank real slow then finally start. changed the battery started fine. now when i try to start it nothing just the fender solonoid clicking once. replaced solonoid on the fender replaced terminal ends. tested battery ground by hooking jumper cables from neg. to fram and tried to start. could it be the starter mounted solonoid and if so could someone explain exactly how to test it. any help with this would be great. btw sometimes i go out and it starts right up. and sometimes it seems like if i mess with the clutch it starts but that may just be a coincedence. thanks for any help
Dan
Old Nov 7, 2004 | 06:27 PM
catmech's Avatar
catmech
check volts at the starter lead wire.ford has been known to have cable problems.bad ground wire.possable clutch switch.try a set of jumper cables to check ground
Old Nov 8, 2004 | 08:29 AM
srercrcr's Avatar
srercrcr
Clean all connections, to a bright shine, between battery, solenoid, alternator, starter, and ground. Even if that's not the problem, that's one less problem coming up.
Old Nov 8, 2004 | 10:04 AM
paulfix's Avatar
paulfix
Really does sound like your battery and or starter cables. They corrode inside the insulation and you cannot see from the outside. Try removing them and bending them feeling for soft spots. They are cheap to replace
woodstockaz
Feb 14, 2017 08:37 PM
Plankton
May 13, 2015 04:05 PM
gvrangr98
1966 - 1977 Early Broncos
Sep 29, 2009 07:46 AM
blakeusa
Electrical Systems/Wiring
May 4, 2008 09:14 AM
charles jones
16
May 20, 2007 09:14 AM
