coolant
Old Nov 7, 2004 | 08:56 AM
00F-350 stroker's Avatar
00F-350 stroker
coolant
Can I safely go from the green to the ford gold antifreeze in my 00 pwerstroke.got the truck at 73,000 miles and just want to switch so i dont have to worry about the additive. thanks
Old Nov 7, 2004 | 09:30 AM
RedTaurus94's Avatar
RedTaurus94
You CAN do it....it IS possible, but you gotta make double-danged sure you get every drop of that green out of your system before you put in the yellow. A mechanic bud of mine told me that the two will not mix, and in fact they will react unfavorably together and cause a real problem.........
Old Nov 7, 2004 | 09:49 AM
refuse2's Avatar
refuse2
I did it on mine and no problems like said before make there is no green left in it at all and you should be fine.
refuse2
Old Nov 7, 2004 | 05:07 PM
00F-350 stroker
thanks just wanted to make sure someone did it and that it was ok.
Old Nov 8, 2004 | 06:38 AM
Skeetshooter's Avatar
Skeetshooter
I did this on my 00 PSD, it is a huge pain in the butt. I performed 7 flushes with distilled water just to eliminate all of the green coolant. This mod is “Not” even close to being worth all of the trouble for what you accomplish. If you decide to make the green to gold change, allow 2 days to complete the switch safely. I have the scaring on my right hand and arm as proof of what can happen when you remove the drain plugs from the block before the coolant has cooled… Jeff in NM…OUT
