Motor shakes ?
Old Nov 7, 2004 | 06:00 AM
SL1CKR1CK's Avatar
SL1CKR1CK
Motor shakes ?
do 429 motors have directional pistons and if so is weight inside or out ? Im not used 2 a hotrod motor maybe its the cam im hearing lol Motor was just rebuilt. Thx Rick
Old Nov 7, 2004 | 09:39 AM
mark a.'s Avatar
mark a.
I believe all v-8 pistons have offset pins. There should be a notch or a arrow pointing to the front. If you put one in backwards it will have a nock / rattle at highway speeds.
Old Nov 9, 2004 | 10:09 AM
SL1CKR1CK's Avatar
SL1CKR1CK
ok ive got heads off and arrows are not all pointing at the front of the motor.So do i need 2 take motor out again and start over ? Thx Rick
Old Nov 9, 2004 | 10:27 AM
SL1CKR1CK's Avatar
SL1CKR1CK
also if i have 2 pull motor apart again.Just so i dont have 2 do this again lol .Rod caps have a arrow also so all i have 2 do is make sure rod cap arrow and piston notch is pointed at front and im ok right ? Thx
Old Nov 9, 2004 | 01:14 PM
loveoldtrux's Avatar
loveoldtrux
Slickrick --- if you've got a hot cam in the motor, the truck'll shake, too....
My Lunati has got quite a bit of overlap / duration and sounds great but "rocks the ship" at traffic lights.....
Old Nov 9, 2004 | 04:37 PM
BigRed350's Avatar
BigRed350
Just for the record, not all V-8's have offset pins, but the 429/460's do!
Old Nov 10, 2004 | 09:08 AM
mark a.'s Avatar
mark a.
I would make sure the rod and piston are not in backwards. There are #'s on the side of the rods for the bore / throw that their supposed to be in.The #'s should be facing out looking at them with the pan off.
If all the #'s are facing out on the rods and the notch / arrow on the piston is facing to the rear, then the piston is on the rod backwards.
Old Nov 10, 2004 | 11:46 AM
airharley's Avatar
airharley
Just out of curiousity.... Who assembled the rotating assembly? And to add to Mark A. comment, one side of the connecting rod will have a beveled/rounded egde while the other is a 90 degree/flat endge. The flat edge is for both conrods to swing while next to one another. The #'s are for what position it was assembled in. Not all conrod caps are marked from the factory. But the stamping is to help you reinstall the right cap on the rod for inspecting the bearings.
