Glow Plugs, cost, testing, pulling...
Old Nov 6, 2004 | 10:18 PM
RawPower's Avatar
RawPower
Glow Plugs...
Is there anything special used to pull them, because Ive just been using a pair of pliers...
How much does it cost to replace glow plugs?
How much does the GP tester cost?
Old Nov 7, 2004 | 03:29 PM
rob_w's Avatar
rob_w
It's been a while since I had to replace mine, but I think they ran about $8 a piece. Normal tools should be able to remove them. A quick test with them installed is with a test light. Hook the test light to the battery and touch the electrical tip of the glow plug. If the test light "lights" it's probably good. If it doesn't "light" it is definitely bad. Hope this helps.
Old Nov 7, 2004 | 07:45 PM
Dave Sponaugle's Avatar
Dave Sponaugle
I use a 1/4" drive 3/8" deep socket with a universal and a couple of different length extensions. You will be talking to yourself changing the ones under the turbo.
A neat socket I saw somewhere had a hex made on the top so it could be turned with a wrench. That looked like it would work well for the under turbo plugs. But as it would have to be, I saw it when I did not have a turbo, now I have one and can not find it again.
If you have a good ohm meter the plugs should read about 2 ohms each with a cold engine.
The test light will find most of the bad plugs, but if it shorted to the case when it burnt the light will light but the plug is no good.
Motorcraft/Beru plugs can be had at Autozone for around 10 dollars each, don't put the other kinds in there, they will cause you headaches later.
Old Nov 8, 2004 | 04:08 PM
Dieseldan7.3's Avatar
Dieseldan7.3
I rewired my plugs to the switch and it hasnt been starting worth a dam, I think I have a bad plug. Im going to try to spend 80 bucks on all new Motocraft GPs to see if it helps.
mattt181
Jun 10, 2017 10:01 AM
Y2KW57
59
Jan 29, 2017 01:44 PM
Padlock
Oct 26, 2014 08:09 AM
mrsvegan
17
Oct 19, 2013 07:26 PM
Barndog29
35
Nov 4, 2005 08:23 PM
