trans. pressures and superchips
Old Nov 5, 2004 | 10:36 PM
jcab's Avatar
jcab
Anybody having problems with superchip change in oil pressure from using superchip causing leaks in transmission??? Thanks Jeff
Old Nov 6, 2004 | 10:11 AM
popkorn's Avatar
popkorn
If oil is coming out of the front of the trans it's probably worn out. I had this happen to me. Trans would pour oil out after towing,next day would be fine no leak
Old Nov 6, 2004 | 11:16 AM
Biwanylo's Avatar
Biwanylo
May be front seal the one that goes around the converter. When you tow it bulds more PSI. I Had a Jeep that did this when I stuck it in some clay and the tires would not spin atf pushed passed the front seal. That scared me but it never did it again. I have my Superchips set at the lowest setting and so far so good I love it. When i tow my 7,500# toy box
Old Nov 6, 2004 | 08:18 PM
MRBASS's Avatar
MRBASS
I have a new SCMT 1705 Tuner and I dont believe it makes any difference to my tranny except for maybe on the highest setting.The older 1700 model tuner i had made a big difference, nice firm shifts for sure. My Front pump seal started puking fluid about 39,000 miles, had that replaced and 55,000 so far and no leaks yet..
Old Nov 6, 2004 | 08:49 PM
jcab's Avatar
jcab
scmt
Thanks for the reply. Why did you change to scmt if 1700 has more power, from what i've heard they perform better than flip chip. Jeff
Old Nov 6, 2004 | 09:28 PM
MRBASS's Avatar
MRBASS
I wanted the 1705 for the code scanning capabilities, figured it was newer and better I regret letting the 1700 go, was gonna keep it but somebody waved cash in my face...
