gear ratio?
Old Nov 5, 2004 | 08:47 PM
frdstpsd98's Avatar
frdstpsd98
gear ratio?
Does anyone know the best gear ratio for a 98 F-150 4.6 with BF 33's? Looking to pick up somemore low end and wondering which way to go. Thanks.
Old Nov 6, 2004 | 08:33 AM
mark a.'s Avatar
mark a.
Somewhere around 3.70's
Old Nov 6, 2004 | 01:01 PM
SoCalDesertRider's Avatar
SoCalDesertRider
Since the 4.6 likes to rev so high and develops it's power at higher rpms, I would go with at least 4.10's, and lean to 4.30's if you offroad with it or live in an area with alot of hills. I run 4.56's with my 33's because I haul a camper and pull a trailer and the 351 in my F350 needed some gearing help to get the job done. Since you likely have overdrive, there isn't much reason not to have the lower (numerically higher) ratio gears. The overdrive gear will take care of freeway cruising rpms so still get good mileage at reasonable highway speeds.
Old Nov 6, 2004 | 01:15 PM
frdstpsd98's Avatar
frdstpsd98
Thanks, thats a big help.Just out of curiosity do you know what the stock ratio is?
Old Nov 6, 2004 | 03:00 PM
kspilkinton's Avatar
kspilkinton
Probably 3.55s stock, check the door jamb and match the code to our web site door sticker translator.
-Kerry
Old Nov 6, 2004 | 03:18 PM
frdstpsd98's Avatar
frdstpsd98
what site?
Old Nov 6, 2004 | 03:30 PM
frdstpsd98's Avatar
frdstpsd98
Thanks kspilkinton they are 3.55's. So 4.10's would probably be perfect. Thanks guys.
ol_geezer
Feb 22, 2003 09:41 AM
Jimbare
Nov 25, 2002 07:32 PM
Ken00
1983 - 2012 Ranger & B-Series
May 22, 2002 08:26 PM
Curtis360
1997 - 2003 F150
Apr 4, 2002 08:54 PM
bluepony79
Aug 8, 2001 10:05 AM
