bench to capt. chairs
Old Nov 5, 2004 | 05:36 PM
kc73's Avatar
kc73
i have been thru a lot of old posts and did not find the info i need. is this a bolt in or do i need to drill new holes and would i have trouble drilling new holes? i would like to hear from someone who has actually done this. '95 f150 super cab 4x4. tks for any help.
Old Nov 5, 2004 | 05:46 PM
dammford's Avatar
dammford
yep you have to drillto do it right!!! it's easy it you have the tools.... i did it and i welded nut to the body under the floor so i could remove them easy "it a pain to use a nut and bolt system becouse you would have to hold the nut and turn the bolt!! pain !! but if you don't have acess to welding.. than the nut and bolt would work
Old Nov 5, 2004 | 08:04 PM
brown 4x4's Avatar
brown 4x4
If you have the 40/20/40 bench it is a direct bolt in. I'm guessing you have the regular bench though. The holes for the center console are already there. You may even be able to tell where the seat bolts go since the console holes are already drilled.
Old Nov 6, 2004 | 01:33 AM
Villagemonkey's Avatar
Villagemonkey
1990 f250 bench to capt chairs
hi guys
is was thinking of doing this to my 1990 f250, i need to know the same things, what captian chairs can i fit straight in , or if not straight in which are the closest fit.
i have a reg, cab ....
cheers Matt
joey2fords
Garage & Workshop
26
Jun 15, 2014 06:16 AM
rescue947
1983 - 2012 Ranger & B-Series
Apr 5, 2013 08:22 PM
Bozworth
Sep 13, 2011 06:53 AM
f1001969mike
1978 - 1996 Big Bronco
Aug 28, 2011 11:45 AM
19mach69
Jul 21, 2010 02:17 AM
