how often
Old Nov 5, 2004 | 02:35 PM
tofer76's Avatar
tofer76
how often
how often do u guys change your atf and the rear end and the tren case and all drivetrain fluids
how and how often with what
never bothered with it and need to check it out
i dont have a manual so any maint logs would help
Old Nov 5, 2004 | 06:45 PM
mike93's Avatar
mike93
ATF-- 15k or once a year for heavy use (wheeling, towing etc.) or
30k mi. or every 2 years light to normal use
T/case at the same time i do my auto tranny as it uses ATF.
Diffs--maybe 30k under heavy use or 60k light use.
don't forget your front bearings, u-joints and anything else greasable in the suspension. these need your attention a lot if you do quite a bit of off roading (wheeling) in mud/water and/or sand.
but under normal use do this twice a year.
front bearings once a year. my book says 30k.
This is what i try to follow.
