A/C disconnect
Old Nov 5, 2004 | 01:21 PM
Dett's Avatar
Dett
A/C disconnect
I have a 1977 F-250 with factory air. It needs to be charged but I don't want to do it until next spring. Will it hurt the A/C if I take the belt off of the compressor? The compressor is making a little noise, and since I don't need to use it for a while, I would like to remove the squeaking sound it is causing. Is there a way to lube the compressor as well to eliminate the squeaking?
Thanks for any input,
Dett
Old Nov 5, 2004 | 05:04 PM
94van's Avatar
94van
The compressor is lubed internally by oil in the freon. The noise you hear may be just a noisy clutch. No harm would come by bypassing the compressor. Just go get a belt for your vehicle without A/C.
Old Nov 5, 2004 | 08:41 PM
Pikachu's Avatar
Pikachu
I really wouldn't disconnect the compressor. Long periods of non-use can allow it to sieze.
Old Nov 17, 2004 | 10:45 PM
WILL210's Avatar
WILL210
Will210
It will not hurt to take the belt off the compessor. The noise maybe the clutch or pully going bad
Jammer-1
Jan 11, 2017 06:29 PM
Redwolfbuddy
Jun 27, 2013 10:41 PM
Dett
36
Nov 26, 2004 11:56 PM
explorer72
Nov 25, 2004 11:44 AM
Dett
May 10, 2004 08:35 AM
