Bronco II Ford Bronco II
power window motors.
Old Nov 4, 2004 | 11:33 PM
MonoxideChild's Avatar
MonoxideChild
yay!
just put in new nylon fittings into my window motors and they work like a dream.
it wasn't that hard took around 1.5 hours for both motors + install of new fittings.
I own a 90' bronco II 2x4
Old Nov 5, 2004 | 08:36 PM
Ken00's Avatar
Ken00
Glad to hear you got them fixed!!!
What did you have to do??
Old Nov 6, 2004 | 01:42 AM
MonoxideChild
pretty basic, take window motor out (3 bolts) take flat head screw driver, pop gear off, scrap out old fittings, put new nylon fittings in(found on ebay for 5.95 each or 9.95 for both plus 1.75 for shipping)
put window motor back in, I pu tin two bolts cause the left bolt is a pain in the *** to get too. it's secure and it'll take me less time to pop the motor out if I even have to do this again.
Old Nov 6, 2004 | 07:21 PM
SquatchMobile's Avatar
SquatchMobile
Thanks for posting about these! I "think" this is all I need to do for my pass. door. Before you took the cover off, were you able to hear the motor running, but just not lifting the window?
Thanks!
-Sarge
Old Nov 6, 2004 | 10:19 PM
Ken00's Avatar
Ken00
Thanks for the details!!!!
Old Nov 7, 2004 | 12:53 AM
MonoxideChild
Thanks!
-Sarge
Correct, I could hear is spinning, but no window movement at all.
So, i did some research and found these nylon fittings, which I guess are a common problem of aging window motors, I guess I should have did a step by step.
sorry about that, never really dawned on me.
Old Dec 3, 2004 | 08:48 AM
Bonesdc's Avatar
Bonesdc
I've got a '89...When I see these nylon parts listed on ebay, they don't include '89. I had to buy a new part (I think it was the whole housing, not the motor though) for the drivers window. I now have to do this for the passenger window and I wonder if I should try the $5.9 fix!?
Old Dec 5, 2004 | 11:46 AM
MonoxideChild
If ou can put a window morotor from any other yea in your truck, then ths fix will probably work.
as long as you hear the window motor going.
