line on yoke
Old Nov 4, 2004 | 11:14 PM
blumpy's Avatar
blumpy
line on yoke
went to chicago drive line to get drive sharft cut and they said some berring was bad because lines on yoke ? is there truth and can i fix with up
Old Nov 4, 2004 | 11:41 PM
paulfix's Avatar
paulfix
They probably mean you had rust lines coming out of the yoke bearing in the u joint. This is caused by the bearing seal failing and the bearing geting rusty and breaking up. They are cheap and east to fix esp if the shaft is of the vehicle
