grinding when shiftin into 2nd...
Old Jul 28, 2002 | 05:43 PM
ol_geezer's Avatar
ol_geezer
Old Jul 28, 2002 | 11:01 PM
tonyevans69's Avatar
tonyevans69
when i pull out onto a road really fast and shift into second it grinds.. and uhh.... i dont know what else to say but does anyone know what it does this? thanks.
tony
Old Jul 29, 2002 | 08:14 AM
tomw's Avatar
tomw
Post grinding when shiftin into 2nd...
Your blocking rings or synchronizer rings are getting worn out. 'spensive to fix.
You might try checking the lube level in the trans, as Rangers are know to puke their grease out the top thru the 'rubber plugs' that fall apart. As a matter of fact, you should check the level even though you do not see evidence of leaking. Just because. Could be getting out any number of places, a bit here, a smidge there, all adds up.
Also, try replacing the lube. Sometimes that will help 'lazy' sychros get by for a while.
Easiest thing to do: Doc sez, if it hurts when you do that, stop doing that.... i.e., quit speed shifting. It'll last a lot longer.
tom
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
