Offroad & 4x4
Locker ?s
Old Nov 4, 2004 | 10:03 PM
scottie2hottie's Avatar
scottie2hottie
Question Locker ?s
Got a question on Lockers here ya'll. What I'm looking for is a manual 100% lockup deal. What I mean is, I want to be able to switch on & off completely, when it's on both wheels spin no matter what(except broken things), when it's off I want it to act like an open differential. Gotta be strong too, high hp/tq engine(603/657) up front and 38" tires all the way around.... So what's the best?? Don't care about the function that makes it lock(ie air, electric) It's just gotta be strong and durable! Thanks!
Scott
Old Nov 4, 2004 | 11:38 PM
fishmanndotcom's Avatar
fishmanndotcom
either ARB air locker or TracTechs Electracs! both very reputable and they fit your description perfectly
-cutts-
Old Nov 5, 2004 | 09:20 AM
rlh's Avatar
rlh
The Eaton ELocker and ARB are full spools when locked and open when off. The Electrac and Ected are ls when off. The T-turd in Heeps is similar to the ARB.
Old Nov 5, 2004 | 09:43 AM
Momudder720's Avatar
Momudder720
What they said. ARB or E-locker.
Old Nov 5, 2004 | 03:44 PM
scottie2hottie
I've heard that ARB seems to have problems with their air seals...Is this true?
Scott
Old Nov 5, 2004 | 03:52 PM
proeliator's Avatar
proeliator
Yes, its true. If I were to pick between the two I'd probably go with the elocker.
Old Nov 5, 2004 | 04:06 PM
scottie2hottie
Thanks for your honesty!
Scott
Old Nov 5, 2004 | 04:16 PM
ivanribic's Avatar
ivanribic
It really kills me that there's no e-locker for the D70. I'll be going ARB's but I'm a little unsure about the whole air system. All I can say for sure is a LOT of people have used ARB's for some hardcore stuff and they still have a really good reputation. I figure they must work more often than not.
Old Nov 5, 2004 | 04:21 PM
scottie2hottie
I've never heard they werent strong, just the seals go bad easily and the air locker becomes basically an expensive open carrier...and They don't even make an eLocker for the 9 inch or D60?
Scott
Old Nov 5, 2004 | 04:33 PM
proeliator's Avatar
proeliator
Well, I wouldn't say its as bad as all that. As Ivan pointed out, they are used succesfully for hard use by thousands of extreme wheelers. But they certainly have more points of failure than the elocker. It kills me that they don't make one for the 70 either. I'll think we'll be seeing more options in the next year though.
Old Nov 5, 2004 | 05:22 PM
bremen242's Avatar
bremen242
A lot of the ARBs have been redesigned with newer seals that don't blow out as easy.
Old Nov 5, 2004 | 05:44 PM
rlh's Avatar
rlh
Scott
They do make an eaton ELocker for the D60. I don't think they have one for the 9" though. The case and gears on the ELockers are damned solid, but I'm sure Pro can break one as he can break an iron anvil if chevit pulls up beside him!
Old Nov 5, 2004 | 06:33 PM
ivanribic's Avatar
ivanribic
They also make the Detroit Electrac for the D60, both 30 and 35 spline. That was my original plan before this forum corrupted me and stuck a D70 under my truck.
Old Nov 5, 2004 | 06:41 PM
Texan1983's Avatar
Texan1983
how much do those electracs and eaton versoins run for in a d44 and d60?
Old Nov 5, 2004 | 06:58 PM
ivanribic's Avatar
ivanribic
Don't know about the Eatons but the Electrac runs right about $800 for both the D44 and D60. Another $200 if you want them chromed.
