I belive i found the problem
Old Nov 7, 2004 | 11:44 AM
  #31
barebackjake's Avatar
barebackjake
tappet failure
tappet in the intake valve (the one that bent) is stuck as stuck can be, cant even dissasimble it. i looked closer at the pistons and there is a very very slight mark from a valve hitting it. the pistons in our trucks are very hard and the valves are too. and the tubes are mild steel. think when intake tube bent, it bent into the exaust vavle tube and thats what broke that. the tappet in the exaust tube is in serviceable condition. works just the way it should. id just replace them all if they wernt $45 a piece, cant get the camshaft follower guide till tommorow so im gonna pull all my tappets and clean and inspect them just to make sure i dont have another one about to do it again. Is there anything i need to to do thoose injectors while i have them out (execpt for sending them to swamp for a set of babies or 175's) havent decided on which ones yet....well my wallet has to recover from this first.
Old Nov 7, 2004 | 01:37 PM
  #32
mech2161's Avatar
mech2161
Sounds like the chain of events are starting to replay. Should send this one to CSI, see how they figure it out.
Old Nov 7, 2004 | 02:52 PM
  #33
Kwikkordead's Avatar
Kwikkordead
I would at the very least replace the valves that hit the piston. They may not show it, but they are bent enough to doubt thier usefulness anymore. Especially if they hit the piston crown with enough force to bend the push rods like that. You also might find that it's cheaper to just take the head to the machine shop and have them go through it.
Get new o-ring sets for the injectors. Last I heard they were in the neighborhood of $14.00 per injector from Ford. A past post also stated: "Don't bother looking around, you won't save that much, and with Ford you know that you are getting the right type of rubber in the o-rings."
Also make absolutely positively sure that the new lifters (you'll probably have to buy a whole set) slide right into thier bores without any resistance other than oil viscosity. If you pull them halfway back up they should slide right down again. Absolutly no hangups anywhere. If all that checks out you should be able to get the truck back on the road again.
God Bless your efforts.
Dan.
Old Nov 7, 2004 | 03:56 PM
  #34
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Definitely do the o-rings. Make sure you let them sit for a while after you put the new ones on so they can shrink back up a little....makes them easier to get back in the hole. Also, a little engine oil mixed with some petroleum jelly make for a super slippery installation lube.
Old Nov 7, 2004 | 07:50 PM
  #35
barebackjake
checked valve guides and valves everything is looking good there also. gonna put it back togethor tommorow
Old Nov 8, 2004 | 07:51 AM
  #36
Kwikkordead
Just to make sure that the valves are not bent, turn the head upside down so the combustion chamber is pointing straight up and level. Plug the injector hole and glow plug hole with a rag or something and fill the combustion chamber with some solvent or diesel or other thin liquid. Look to make sure there is no fluid running out of the intake or exhaust ports to indicate a bad seal from a bent valve stem. Sometimes it's tough to tell when the valve is out and in your hand. You'll get a very slight trickle and no need to be alarmed by that, but a bad seal on the valve will allow it to run out within seconds. Better to find out now than later.
Old Nov 8, 2004 | 07:54 AM
  #37
Kwikkordead
Hey! I am going to make some of that concoction and have it around the shop. Great idea.
Old Nov 8, 2004 | 10:22 AM
  #38
barebackjake
yeah i use red diesel to leak check the head cause it has the uv dye in it around here so you can shine a black light down the ports and it stands out like a sore thumb. it sat overnight and not a drop went anywhere. valves slide in and out snugly not to tight not too loose and the feel the same as the other cylinders. put machinist dye in the valve seats and spun them and they seat evenly. im just **** about builing motors i guess thats my problem. if i wasnt on a time restraint with this i would have the head torn through but the diesel machine shop around here thats worth a damn is 4 weeks out.
Old Nov 8, 2004 | 04:27 PM
  #39
roaky81's Avatar
roaky81
I'm just a shadetree mech (take this with a grain-o-salt), are the lifters solid or hydraulic, is there a valve lash adjustment possible. Too much gap could beat on the rod and cause premature failure. Or better/worse, the lifter failed (if hydraulic) and performed the same damage. Let's not forget the meticulous factory assembly (they never goof).
Old Nov 8, 2004 | 10:05 PM
  #40
Kwikkordead
Ok, that's good. I can't think of any other suggestions for you.
Old Nov 9, 2004 | 05:59 PM
  #41
barebackjake
that head is a bunch of bad words to get back in. im on my second head gasket on thoose trucks you have to put the head in with one head stud in the head. you get in in there you wont get head stud in there. had head stud zipped tyed up but it slid down on me and tore the head gasket. regrouping and trying to figure out how to get the damn thing in. dosnt help how heavy the damn head is, back to work i get.
Old Nov 9, 2004 | 08:33 PM
  #42
Kwikkordead
Yeah don't break your back. And it's half buried under the firewall to boot.
Old Nov 9, 2004 | 10:00 PM
  #43
realhp's Avatar
realhp
Just a question to you all, do you think it could be possible that he lost oil pressure first causing that lifter to seize up in the lifter hole and when the piston tapped the valve it broke the push rod and freed up the lifter and then the cam lobe spit the lifter out? Just something to think about because I am with you all that I just don’t see a push rod just getting bend with out some kind of interference.
Old Nov 9, 2004 | 11:05 PM
  #44
Kwikkordead
Dang it, I have to agree with you there. In all of this there has not really been a real clear "cause of failure". Just the aftermath. So now I am still nervous for Barebackjake on this one.
Old Nov 20, 2004 | 01:31 PM
  #45
vancouverpower's Avatar
vancouverpower
Read this, could be the problem?
http://www.intellidog.com/dieselmann/b_smoke9.htm
