2000 Spark Plug Wiring Mistake?
Old Nov 4, 2004 | 05:30 PM
dougtaylor69's Avatar
dougtaylor69
I'm really glad to have found this site. I'm way to poor to afford most garage service (I'm the sole support for a family of 4)!! I'm generally mechanically inclined and I take care of most of our basic auto maintenance needs myself...but this one is a bit beyond me.
On Saturday, my 2000 Ranger 4x4 3.0L Flex Fuel v6 (wimpy engine!!) made it known that I needed to change the spark plugs and wires. There was an obvious misfire in one of the cylinders...but without the analytic equipment I couldn't tell which one. I decided to replace them all and the wires as well. When that was done, I still experienced the problem. I started second guessing myself on whether or not I put the wires in the correct location and I can't find any kind of diagram that can tell me.
The old plugs were trashed - so it definitely needed to be done. My truck has about 60k miles.
Is there something else I should check? Fuel filter?
Thanks for any help!
Old Nov 4, 2004 | 05:42 PM
Rockledge's Avatar
Rockledge
Welcome to FTE!
This should help with the plugs/wires:
3.0L Firing Order / Cylinder, Coilpack Terminal ID Numbering
Also, yes, changing out the fuel filter is probably a good idea. Make sure you get the right filter for your flex fuel.
Old Nov 4, 2004 | 05:46 PM
dougtaylor69
wow - that's exactly what I need! Thank you!
Old Nov 4, 2004 | 08:32 PM
Thoth88's Avatar
Thoth88
Just a thought, did may be one of the injector connections come loose? get wet?
Old Nov 5, 2004 | 01:50 PM
dougtaylor69
Good suggestion. I will check on that too. Using the diagram, I verified that my wiring connections were correct - thanks again. But unfortunately, I still have the problem.
Guess I've got my weekend cut out for me!
Old Nov 5, 2004 | 05:50 PM
RangerRuss's Avatar
RangerRuss
DougTaylor: Look for the obvious things such as a cracked/loose vacuum hose, corrosion around any electrical connections etc.
Usually Autozone and the like will scan the codes for you. If your CEL light is not on there may be a "stored code" which will point you in the right direction.
Good luck. Keep us informed of your progress.
Russ
Old Nov 6, 2004 | 11:42 AM
dougtaylor69
Thanks again - I'm taking it to Autozone as suggested - that's another service I wasn't aware of - hopefully I'll get some new info.
