Diablo Predator
Old Nov 3, 2004 | 07:05 PM
bigballin13139's Avatar
bigballin13139
Exclamation Diablo Predator
the predator website says you can monitor live data while driving? is this egt's , boost, trans. temp, what??? does anybody out there know??
i also have a bullydog chip, is this stackable with the predator???
FINALLY, does anybody out there know of a digital monitor that is capable of monitoring TRANS. TEMP as well as egt's and boost? preferably something that is a tuner as well??? im probably asking for a little tooooo much but it would be nice to have one gauge that monitors everything i just mentioned AND can increase performance like a tuner does AND is stackable w/ the chip i already have. if you cant tell already, im trying to build a performance system and would appreciate any advice!
Old Nov 3, 2004 | 07:31 PM
gunfrk's Avatar
gunfrk
I can't imagine that those things can be monitored because you have no senders onboard.
I know there is one called an X-monitor I think. It monitors boost, exhaust temp and maybe even trans temp.
As to stackable chips and programmers, The chips are burned to your 'puter and the programmer also have to be programed to your computer code. That would eliminate being able to use both (but I have been wrong before.). I have a 4 bank Bully Dog myself and it is actually more than I need. I wish I had been privy to Quadzilla's idea of having the extreme mode reburnt to just an idle controller set at 1100 rpm. before I had it burnt to my 'puter code.
Old Nov 3, 2004 | 09:14 PM
countrysF250's Avatar
countrysF250
I have the banks six gun it monitors egt,boost and amount of fuel being burned it can also be stacked with other chips or tuners the six gun by itself was a big differance, although im thinking about adding the banks bosshog to it for a little extra.
Old Nov 3, 2004 | 09:29 PM
bigballin13139
I TOO WANT THE SIX GUN! do you have other gauges i.e. egt and boost, i heard of people having BOTH the six gun AND having the xtra gauges just in case and i was wondering if you can hook up MORE THAN ONE gauge in the same circuit without frying THE six gun!!!
Old Nov 4, 2004 | 07:21 AM
countrysF250
The six gun has a wiring harness that comes out the back that u can plug into seperate gauges but i think they have to be banks digital gauges to work but, u could add another boost gauge fairly easy the pyro might be another story unless u wanted to drill and tap another hole in ur manifold which i think is unneede im going to get a boost gauge and trans temp gauge and let the six gun just displsay the egt's.
