EGR engine codes...
Old Jul 28, 2002 | 03:06 PM
Charnsen's Avatar
Charnsen
EGR engine codes...
I own a '92 Ranger 4x4 with the 4.0L engine. I keep getting fault code 34 - how is this possible when 90 - 92 Ranger w/ 4.0L engines don't have EGR??? I'm also getting code 57 and 73 - from memory. The 'Check Engine' light illuminates after driving for about 5 - 10 mins (once vehicle is warmed up). Turning it (the truck) off and then back on will clear the fault for a few minutes. Doesn't appear to be damaging but would like to clear the problem. Thanks.
Old Jul 31, 2002 | 12:47 AM
lol100's Avatar
lol100
EGR engine codes...
how do you pull the ECU codes? which pins do you short out?
Old Jul 31, 2002 | 06:36 AM
ranger pat's Avatar
ranger pat
Veteran: Navy
EGR engine codes...
If you keep getting code 73, I suspect the TPS is reading too high. Code 57 would indicate an intermittent fault in the neutral safety switch.
Old Jul 31, 2002 | 11:04 AM
Charnsen's Avatar
Charnsen
EGR engine codes...
I've since replaced the TPS (got rid of code 73) and found code 41 during the Engine running test - which I've cleared as well by replacing the Oxygen sensor. Keep getting code 34 though - just about out of ideas...
Thanks for the replies - keep 'em coming!
Old Aug 11, 2002 | 11:12 PM
tjohnson's Avatar
tjohnson
EGR engine codes...
I had a mechanics teacher back in high school that told me some fords will always show an EGR code. I think there might be truth to that as both 87 rangers I've driven have showed it.
Travis
Old Aug 12, 2002 | 08:34 AM
Ken00's Avatar
Ken00
EGR engine codes...
Are you sure the correct ECU is in the truck?
I believe 87s had EGR.
Old Aug 12, 2002 | 11:40 AM
loudfords's Avatar
loudfords
EGR engine codes...
